Intermittent electrical problem
I have a 93 Ex coupe. It just started to act up in the hot weather. The guages, spedo and tach will go to zero now and then. The car doesn't want to crank over either. It is very slow to turn over. It seems to be getting a spark and will run, and the altenator seems to be charging. The battery seems ok to. I replaced the ingition controll module last year and the distributor and wires. Not sure if I have a ground some where or what?
Any sugestions would be greatly appreciated, Thanks!
RE: Intermittent electrical problem
Thanks, I will check it out at autozone. That would make sense. I checked it with a volt meter and the voltage was good, but it may be another problem with the battery. I've had cells go out before. I've had problems with my other civics in the heat with batteries. I had one explode when I turned the key and smoke came out I thought I was getting pranked. Never seen anything like it.
laack
04-20-2009 09:10 AM
binrocha
09-06-2006 10:31 PM
ParisDakar
12-27-2005 12:38 PM
02, 97, automotive, checking, civic, electrical, ellectirc, honda, intermittent, intermittin, issue, problem, problems
