Input Shaft Bearing? Please confirm.
Hey guys, I'm gonna be buying my clutch kit, flywheel, axles, and lower ball joints soon and there's also a bearing I'm gonna have to replace.
I think it's the Input Shaft Bearing, but I just want to make sure i've diagnosed the problem correctly before I go buying stuff.
When I am at idle, there is a "shhhhhhhhhhhhhhhhhhhh" noise. When I push the clutch pedal, the noise immediately goes away, and when I let off the pedal it comes back. I can hear it while driving and it makes the typical worn bearing sound. It increases with the RPMs. Noise stops if I push in the clutch.
So, does this sound like the Input Shaft Bearing to you guys?
-Thanks
-Thanks
I thought it was the other way around... throwout bearing makes noise when you push in the clutch
Trust, sounds like you have the right diagnosis. Have you seen this DIY thread, which I believe is for a 94 Civic? In the service manual, the Input Shaft Bearing is apparently called the Clutch Housing Bearing.
Can you tell me where the bearing is in this picture? (regardless of whether it's visible)
And which one is the input shaft? Sorry, never been inside the transmission before. lol
mtchu736
01-25-2009 12:23 PM
mr honda
03-08-2008 07:47 PM
itsmycivicduty
02-14-2008 05:00 PM
