important question
Old 05-30-2008 | 11:32 AM
saiyen x's Avatar
Default important question
honda civic 2000 hatckback dx automatic
ok its been doing thats for like the 5th time in less then 2 weeks
i start accelering and when i stop accelering my car keep accelerign without me pushing on the fuel pedal..
does anyone know what it could be and how much it cost to repair it ?
Old 05-30-2008 | 11:44 AM
saiyen x's Avatar
Default RE: important question
any response would be appreciated <33
Old 05-30-2008 | 11:49 AM
1) Check whether the carpet under the gas pedal is bunching up and interfering with pedal release.
2) Check the throttle cable and throttle body for sticking.
Old 05-30-2008 | 11:52 AM
saiyen x's Avatar
ORIGINAL: RonJ
ok and how much could it be a throttle cable or body if it was that ?
Old 05-30-2008 | 11:58 AM
Not sure on prices. Call your mechanic or Honda dealer for this information. Other HCF members may also be able to tell you. Keep in mind that such throttle cable or throttle body issues may be fixed in some cases by cleaning rather than replacing. Start simple by inspecting the carpet around the pedal.
Old 05-30-2008 | 12:06 PM
i would try spraying the throttle body linkages with some WD40 or somekinda penatrating oil and work it around throttle back and forth a few dozen times and see it that helps. might want to make sure the cable has alittle play in it with it at rest... if it stays tight ya may have to slightly adjust the cable alittle looser.
Old 05-30-2008 | 01:46 PM
saiyen x's Avatar
how does i adjust the cable ?
Old 05-30-2008 | 02:57 PM
if you follow the throttle cable youll find a threaded shaft with 2 nuts that sandwich a metal bracket.... simply lossen one nut and move the other to tighten or loosen the cable and then jam the 2 nuts back together. pretty simple. you want alittle slack in the cable but not to much....
Old 05-30-2008 | 04:13 PM
saiyen x's Avatar
ok and could it be the throttle cable itself that could be the probleme ?
if yes do u know how much can cost a throttle cable ?
Old 05-30-2008 | 04:28 PM
no idea how much anew one costs. i never personaly had a problem with mine but my friends civic was sticking do to some rust around the area.
p3anutboi
08-23-2010 02:24 PM
WellFedHobo
06-07-2009 07:09 AM
plethoric33
03-19-2008 09:38 PM
plethoric33
09-13-2007 03:07 PM
Hot94vtec
08-31-2007 03:16 AM
