ignition/steering wheel lock/ plz help. =/
Old 10-13-2007 | 07:24 AM
fakitzjason's Avatar
Default ignition/steering wheel lock/ plz help. =/
is there a way that you can unlock the steering wheel without the key being turned or watever?
as some of you may already kno, my key will not turn at all in my ignition.
i have tried everything from jiggling the steering wheel and turning the key to putting graphite powder (it actually made the key slide in faster, and i can tell it wants to turn, but the damn steering wheel is locked HARD)
i currently think its my steering wheel lock that is not making the key turned.
is there a way i can unlock the steering lock?
and where is it located in my 04civiclx. thanks
what are some other problems that i can take consider?
please help guys.
Old 10-13-2007 | 09:03 AM
danomatic93's Avatar
June 2010 ROTM
Default RE: ignition/steering wheel lock/ plz help. =/
go to the dealership with your title and they can make you a brand new key to match your ignition!
Old 10-13-2007 | 03:21 PM
I assume you've already tried turning the wheel from side to side while trying to turn the key. If the lock is jammed up you will have to drill the screws out and take it off of the column. If it's like the older models the part with the key cylinder is clamped onto the column, and when it is locked there is a dog that comes out and locks the shaft.
Old 10-14-2007 | 01:14 AM
sparkie's Avatar
Gosh! the cars not that old, try a lockmith
Old 10-14-2007 | 07:30 AM
like said have you tried to TURN THE STEERING WHEEL and then moving the key forwards?
if the steering wheel has pressure on it it will not allow the key to turn forwards..... simply grab the steering wheel and turn it either way that it will go just alittle bit and they key should go right forwards no problem.
its like this on every vehicle with a steering lock
jpnolan
04-14-2009 12:11 PM
tuong
03-04-2008 12:32 AM
that_guy5
02-09-2007 09:09 AM
yesrose
10-05-2005 11:24 PM
helpmeplz
12-15-2004 04:43 PM
