Ignition problem
Old 12-21-2011 | 01:08 PM
caboosethegreat's Avatar
Default Ignition problem
I have a 91 Civic hatch 1.5 i bought about a week ago..
it ran fine after jumping it but wouldnt charge the battery with the alternator
replaced the alternator and charged the battery it ran fine i went inside for a minute then came back out and it wasnt running but the stereo and all electrical systems were running fine
now after replacing spark plugs, oil, valve cover gaskets, fuel filter, and oil filter its still not running. its getting fuel but it sounds like its not firing.
If anyone knows anything or has had this problem and knows how to fix it your help would be greatly appreciated
Old 12-21-2011 | 01:56 PM
Check if the ignition is generating sparks to the spark plug wires. If not, check if the camshaft is rotating.
Old 12-28-2011 | 08:59 AM
Foxxcivicex's Avatar
Having the same problem. My son crossed his wires when trying to jump the car now it doesn't start after jumping it and driving it for a while. I just replaced the alternator before this happened. Did he burn something out when he crossed the wires?
Old 12-28-2011 | 11:12 AM
Trying to run with a spark wire disconnected can blow the coil.
Old 12-30-2011 | 04:47 PM
Found the problem. Battery wasn't holding a charged so after replacing it haven't had any more problems so far.
kinosh
08-02-2006 11:59 AM
xxpl0sive1
06-02-2006 02:20 AM
cinefyl
05-21-2006 12:54 PM
jennytaylor
12-26-2005 05:47 AM
mxs
12-15-2005 03:11 PM
Quick Reply: Ignition problem
