I would really appreciate some help guys!
Old 08-05-2005 | 04:32 PM
blackrocket93's Avatar
Default I would really appreciate some help guys!
Hey, what's up? I am new here but have owned a few civics. I just got my latest, a 93 ex black on grey. My problem is that there is a bushing down in my pass side lower control arm. The problem is that the bolt that runs through the controll arm and the bushing won't tighten, it just turns and turns. Is the nut on the other side of the bolt fixed fto the frame or is there a nut in there? The housing around it won't let you get to a nut on the other side of the bolt or even see one, I am worried, can someone help me to understand what is going on in there and/or how to approach fixing the problem? Any help would be greatly appreciated.
Old 08-05-2005 | 06:49 PM
StifflersMom's Avatar
Cat Fuсker
Default RE: I would really appreciate some help guys!
From what I remember there's a nut welded on there...if it spins it could have rotted off. Are you sure the bolt isn't stripped and that it's the correct length?
Old 08-05-2005 | 07:18 PM
sacicons's Avatar
this problem is what got me started on forums. i couldnt figure out why, after my swap, every time i'd floor it, or hit vtec, it would jerk really hard to the right. after asking on many many many boards, i finally figured it out on my own. the nut DOES fall off occassionally, and thats what happened to you. i used a dremel and cut that hole near where the nut is, and got it just big enough for a wrench to fit through. then i clamped it down, and finally i welded the nut back on. you can leave the nut unwelded, but then every time you work on it, youll need 2 wrenches. not a big deal though. good luck.
Old 08-05-2005 | 08:23 PM
ngoti 8tor's Avatar
[sm=welcomesign.gif] to HCF. [sm=groupwave.gif][sm=groupwave.gif][sm=groupwave.gif]
Old 08-05-2005 | 11:05 PM
Thanks sacicons that helps so much! I was starting to wonder if anyone else had ever had this problem! I am going to tear into it in the morning. thanks again man!
Old 08-05-2005 | 11:06 PM
LEVIII's Avatar
I remeber Sacicons trying to figure this thing out. Took him like a year if I recall.
"Its a small world after all"
Old 08-05-2005 | 11:08 PM
Street Sniper's Avatar
Yeah, how funny is that? Circle of life, you know?
Old 08-05-2005 | 11:17 PM
LEVIII's Avatar
ORIGINAL: Street Sniper
^^^^Post *****^^^^
chasemclemore
05-04-2009 01:58 PM
FlipHKD720
02-17-2008 09:40 AM
Partizan
01-25-2007 09:13 PM
krazy_gurl06
03-31-2006 12:27 AM
Quick Reply: I would really appreciate some help guys!
