i blew my O2 sensor the otherday...
Old 12-05-2005 | 06:35 PM
greeksi's Avatar
Default i blew my O2 sensor the otherday...
its not covered under warrenty because i "over reved the motor" can someone give me an estimate of how much it would cost parts and labor?
Old 12-05-2005 | 07:18 PM
AgentofDarkness's Avatar
Default RE: i blew my O2 sensor the otherday...
I don't know how you can blow an O2 sensor by overevving the engine but anyway an O2 sensor is about $60-$100 i think. I dunno how good you are with cars, but it isn't too hard to change. You need an a wrench (you can find an O2 sensor socket). You take out the old O2 sensor (unbolt it from the exhaust) and disconnect the connector. Then you bolt the new O2 sensor in and reconnect the connector. I haven't taken too many O2 sensors out, but there is an engine in our shop (4 cylinder mitsu) and we always play with the O2 sensor (take it out and put it in) so i've done that a couple of times.
Old 12-05-2005 | 09:26 PM
Chimera02EX's Avatar
This is REAL easy, get an adjustable wrench (or if you have a 22 or 23(?)mm wrench that will work too) not totally sure about the mm size so stick with the adjustable wrench, unplug it frist as this will allow the wiring to twist freely as you are unscrewing the O2 sensor. If you get an universal O2 sensor (like Bosch) you will need to splice some wires, no biggie, black to black, grey to grey, and then there are 2 whites hook them up, (with the whites it doesnt matter how you hook them up). Screw the new O2 in and plug it back up. and your done.
Old 12-09-2005 | 06:56 AM
ngoti 8tor's Avatar
ORIGINAL: greeksi
First question that comes to my mind is : How does your Honda Dealer know you over revved the engine?
redblur07
EK Swaps
05-01-2008 02:28 PM
nuck
07-21-2005 09:29 PM
grncivicvtec
03-15-2005 03:18 PM
cvcman
01-17-2005 08:25 PM
Quick Reply: i blew my O2 sensor the otherday...
