How to inspect brakes?
Hi I want to know how I can inspect my brakes because they are a bit sloppy. What do i look for and if anyone has a diagram on how to get to the brake pad that would be awesome! Its a 2002 honda civic lx
First check the level of brake fluid. If you stop normally but then the pedal sinks down, master cylinder is bad or there's a leak. Does the hand brake work properly? If not, rear brakes probably aren't adjusting themselves like they should. This will cause the brake pedal to travel further than normal.
To check disk brake pads remove the wheel and look through the inspection slot. Worn out pads won't cause "sloppy" brakes though. When they are finally completely gone you will still stop but there will be very loud noise from metal to metal contact.
jonsaidthat
05-30-2010 09:30 PM
jonsaidthat
07-10-2008 01:18 AM
ahhsimon
06-14-2006 09:52 AM
