How to get crankshaft pulley off??
Old 03-25-2008 | 06:42 PM
museboy07's Avatar
Default How to get crankshaft pulley off??
Well I'm going to be changing my timing belt, tensioner, and water pump this weekend and I need to know if I need a puller to get the crankshaft pulley off. Like a 2 or 3 jaw puller, or like a 3 hole steering wheel puller type deal? Also, there's a rattling/knocking sound coming from my timing belt area. It only does it a low rpms. Could it be the tensioner or something going bad?? Thanks for any info.
Old 03-25-2008 | 07:45 PM
Default RE: How to get crankshaft pulley off??
The hard part is getting the bolt out. A decent impact wrench will save a lot of frustration. Once the bolt is out, the pulley will just slide off by hand. No puller needed. When removing the pulley, a little metal key will come loose from the groove in the pulley, be careful not to lose it.
Old 03-25-2008 | 07:55 PM
AgentofDarkness's Avatar
You need an impact, make sure you turn it the right way. Learned that one the hard way. Get PB Blaster, lots of it.
Old 03-26-2008 | 04:15 AM
museboy07's Avatar
Well I have an impact...a nice MAC one. But what is that key used for?
Old 03-26-2008 | 09:57 AM
93civicdx's Avatar
that key keeps the pulley from spinning on the crankshaft. basically it holds it in place. you will see when you take it apart
Old 03-26-2008 | 10:13 AM
museboy07's Avatar
Ok great. I actually might be doin this after class today around 6pm. Anything else I need to watch out for before i dive into it??
Old 03-26-2008 | 10:27 AM
93civicdx's Avatar
just watch the way everything comes off and u should be ok. If i remember right the bolt is reverse threaded but i could be wrong.
Old 03-26-2008 | 10:34 AM
ORIGINAL: 93civicdx
The bolt is NOT reverse threaded.
Old 03-26-2008 | 10:47 AM
93civicdx's Avatar
thanx Ron i could not remember if it was or not
Old 03-26-2008 | 12:19 PM
ya with the timing belt just be sure to line up the upper cam timing marks and the lower crank oil marker. i didnt and my belt was off a tooth or two. it ran but pretty bad. just a hassle since i didnt pay attension to the lower oil mark....
