How to get access to passenger side window?
My car was broken into a few months ago and they smashed through the pass. window so I had it replaced. Now when I drive I hear this annoying noise like a little piece of broken glass rattling around inside the door either that or its the window itself rattling. Anyone have pictures on how to take off that section of the door to gain access and check out the window storage area? By the way, 94 Civic DX
RE: How to get access to passenger side window?
Go to Honda Civic/CRX/del Sol 1984-1995
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
sdt790
sdt790
ya typical for busted windows.... get a shop vac and a small flat screw driver with the door panel off suck as much glass as ya can outta it then with the small screw driver run it down the bottom of the door and vacume again.... do that afew times and it should get most the glass outta it!!!! also check the drain holes in the doors as well for some glass...
worst part about glass inside the door is it can clog up the water drain holes and when it rains hard water gets into the doors and cannt get out! and preaty much makes a RUST TRAP...... which is the main reason cars rust from the bottom....
civicrevolution
04-03-2011 04:27 PM
