hood not opening...
Old 07-10-2007 | 02:53 PM
Rklamb16's Avatar
Default hood not opening...
anyone know how to fix the hood so when you pull the latch it actually opens rather then having someone hold it up while i pull the latch...?
Old 07-10-2007 | 02:56 PM
danomatic93's Avatar
June 2010 ROTM
Default RE: hood not opening...
It's either the latch itself or the hood release cable stretched out. Spray degreaser on the latch, clean it off with a pressure hose (or try to) then lubricate it. If that's not it, it's probably the cable.
Old 07-10-2007 | 07:04 PM
gwl's Avatar
gwl
Make sure that your hood latch is align correctly.
Old 07-11-2007 | 07:00 AM
There's supposed to be a spring on the hood to pop it up about an inch when you pull the latch. It sounds like your helper is substituting for the spring.
PJLambe
12-02-2010 05:01 PM
dukevalentino
08-03-2010 07:44 AM
GregM
07-14-2010 04:15 AM
blinky120
10-21-2008 06:44 PM
tombakers
01-04-2007 09:52 PM
Quick Reply: hood not opening...
