Honda civic 97EX coupe problems plz help
Old 08-27-2009 | 06:50 PM
honda871's Avatar
have you pulled the codes to see why the check engine light is on????
also have you hooked the fan directly to your battery to see if the fan works?
running a engine hot is not good... it short'ns the life of the engine
Hi, I replaced a new radiator, new thermostat, check the radiator fan fuses to
see if any are burn. The fuses are in good condition, So i put 50/50 anti freeze
coolant with the cap off and start the engine to let the coolant kick in
it started bubbling so i think thats good? But the radiator fan wasnt spinning
So i wait alittle bit and when the temperature gauge got to the middle between
cold and hot it still didnt spinning. I turn off the engine and took a speaker
wire connect it from my radiator fan to the +positive battery to see if it is
working. It spins and it works, Maybe its my sensor but im not sure.
2 hours later i was trying to get home my car wont start anymore -.-
all the wires are connect right, Fuses are good, new battery But when i got my key in the ignition it says Check battery and check water
97EKCAL
01-29-2010 10:03 PM
97EKCAL
01-29-2010 12:38 AM
ThunderStump
05-19-2009 11:21 PM
ian125
09-24-2006 01:49 PM
