HID Problem....Help
RE: HID Problem....Help
if you were using HID's then i wouldn't see how that would cause it to blow a fuse, As they are all basically the same bulb, just different connection for the housing. but if they were on and you unplugged then plugged it back in that can cause it to blow a fuse,
at first one the left hand side wouldnt turn on, then i checked the fuse and it was blown, i replaced it and it still wouldnt turn....now 2 weeks later my right one went off andwont turn on...i checked the fuse and it wasnt blown....you think it could be the ballast?
