Hesitation from 2k to 4k? HELP!
Old 06-23-2010 | 08:35 AM
tstephens4's Avatar
It couldn't hurt and most likely needs changed.
Old 06-23-2010 | 09:09 AM
civclxcrab's Avatar
From past experience i would say it could be the fuel filter... Or bad gas....
Old 06-23-2010 | 11:43 AM
bubbadirect's Avatar
UHOH. I have a problem. I can't get the fuel filter off. I can get the one side loosened but can't get the other one. Now what? Take it to someone? UGHH.
Old 06-26-2010 | 05:58 AM
Okay, well I checked the distributor cap (looks good to me) and replaced the fuel filter yesterday. But I am still having the hesitation/roughness at steady speeds (above 2000rpm for example). UGH! When I am giving the car gas to increase speed, I have no hesitation per se, but only feel it when I am driving at a steady speed. What could this be? Fuel pump? Something to do with the throttle?
OH, and now that I have replaced the fuel filter, I don't SMELL GAS FUMES ANYMORE!
Is it time I take it to a HONDA dealer? I would prefer not to have to do that.
Old 07-21-2010 | 03:07 PM
Okay, well it is still happening. Would a bad fuel pump cause the hesitation/misfiring when driving on the highway too or anywhere I am driving at a constant speed? One buddy says it could be the main relay, starter, bad fuel pump.
Old 07-30-2010 | 07:56 AM
Okay, well now I replaced the Main Relay Switch and this fixed the problem with starting the car in the summer heat. Now I still have the hesitation/misfiring while driving. Does this sound like a distributor cap/rotor thing? I haven't replaced that in probably 10 years, so even though it looks good (TO ME AT LEAST), should I replace this part too?
Old 08-01-2010 | 06:32 AM
SilverSedan's Avatar
if they're 10yrs old, I would replace the following: Cap, rotor, spark plug wires, and sparkplugs. Even if they work "ok" the fact remains that they are old and likely corroded and starting to wear or break down.
I had an issue with poor running similar to yours, and replacing those components cleared it up
Old 08-02-2010 | 06:24 PM
Thanks silversedan for your posting! I am gonna do that next. Replace the Cap and rotor, and that should do it! (fingers crossed)
Jeremy Becay
09-27-2013 07:43 AM
HC98
05-27-2008 08:33 PM
elysian
04-12-2006 05:00 PM
gunner11
12
01-27-2005 11:31 PM
gunner11
01-23-2005 07:28 PM
Quick Reply: Hesitation from 2k to 4k? HELP!
