HELPP PLEASE
HELPP PLEASE
ok i have a 1990 honda civic dx and it starts and runs fine then i shut it off and it dont want to start but u wait a lil it will start then if u shut it off it might start 3 or so times and not start again what can i do
RE: HELPP PLEASE
When one sometimes cranks but doesn't start, suspect the main relay. Especially if the check engine light stays on while cranking, it should go out while cranking. Replace it or resolder it. This relay is located under the dash on the left side wall of the car just above the hood release lever.
RE: HELPP PLEASE
Next things to check would be to see if the ECU shows any codes (if it does, they may be old, so reset it and drive until it won't start again then check codes again). Also take one of the plug wires off the distributor and see if it is making sparks when it is not starting. The engine does crank every time but not start, right?
aznxboi19
01-12-2006 08:22 PM
ClayMayTion
01-07-2006 10:35 PM
steven10
03-29-2005 02:11 AM
