Help with Turn signals please
I'm new here and I'm looking for some help. I just picked a 2000 Civic EX 4 door coupe, and the turn signals and hazard flashers don't work. I checked the fuse (it's fine) and I replaced the flasher relay. But they still don't work. Before I spend $125 on a new switch, I hoping there is something else I can try. The headlights and tail lights work.
Thanks for the help.
G-Hog
G-Hog
Check the bulbs, it's possible that all 4 are burnt out, missing, etc. You never know with a used car.
Pry the hazard button out of the dash and make sure it is plugged in. All the circuits go through that button, it is more likely to be the problem as the switch on the column only does the blinkers it doesn't have anything to do with the hazards. Also power for the hazard function comes from a different fuse, which is under the hood I think. The same relay is used for both.
dlion77
01-23-2010 09:03 AM
nyorkrider
06-28-2007 06:36 PM
civicwagon949
04-28-2007 10:07 AM
ripzone829
01-23-2007 09:57 PM
