Help PLEASE!!!
Help PLEASE!!!
Last friday when i was going to work my car just stopped in the highway, when i took it to the mecanic they told me it was the distributor, so they changed for a new one, i piked it up and suddenly the check engine light pop up, i went back to the mechanic and he told me i need a tune up, he connected my car toan OBD II scanner and hes like hidding it so i can't see the result, and he told me again i need a tune up, today i just bought an OBD II scanner and the code that i got is: P1362manufacturer contrl ignition system or misfire, i changed the wires to the spark plugs and the light still the, also, before all this happen my car always start just after turn the key and now it takes like 2 or 3 seconds, its like crancking and starts, please can you guys help me, my car is a Civic Ex 98
Thanks for your help
David [:@]
David [:@]
RE: manufacturer contrl ignition system???
i had something like that this weekend, the light was on and had about 6 codes and 4 of them were misfire codes. the mech just told me to change the distributor cap and rotor, spark plugs and maybe the wires if they dont look bad and it just be good to go.
Ihave change for a new distributor and the rotor and cap are new, i just went to see the distributor and it has a label that says TD80 i look for it on ebay and they sale TD80U for my car and not a TD80, can that be the problem??? because the distributor is different???
DontHateOnEG8
20
09-06-2008 06:49 AM
