Help! obd2a to obd1 p28 ecu problem!!
Old 09-17-2009 | 11:12 AM
PaTKRider's Avatar
Default Help! obd2a to obd1 p28 ecu problem!!
i originally purchased a new obd2a to obd1 conversion harness for a 98 civic ex. has a stock d16y8. i bought a used p28 ecu for my civic in order to chip it. but i tried the ecu with the conversion harness before chipping it and the car started but ran rough. then i took it out and put in original ecu and ran fine. Wondering what could be the problem? the ecu? or the harness?
Then i tried the p28 again but car would not stay running, car ran rough
for a second then died.
Old 09-17-2009 | 11:16 AM
then a cel came on?????
it could be the jumper harness or the ecu..... do you have any friends with a obd1 civic? so you can test your ecu. also where did you get the jumper harness? is it a professonal job?
Old 09-17-2009 | 11:19 AM
PaTKRider's Avatar
Yea im guna check my friends ecu tomorow. But the jumper harness is brand new just opened it. and got it from streetlightz.com it looks professionally done
Old 09-17-2009 | 11:21 AM
PaTKRider's Avatar
and no cel did not come on
Old 09-17-2009 | 07:10 PM
PaTKRider's Avatar
bump plz need help
Old 09-17-2009 | 07:18 PM
did you hook it up in your friends car?
Old 09-17-2009 | 07:28 PM
PaTKRider's Avatar
no not yet. will know tomorow. hoping its the harness because came with warranty but sucks if its the ecu because bought of some guythat said it had no problems. then im out $60
Old 09-18-2009 | 03:55 PM
PaTKRider's Avatar
Just got it checked out by a friend. the ecu worked fine in his 95 civic. Then i plugged his ecu with my harness and car ran fine. then i plugged my ecu with my harness and car started a little funny but after a second the car idled normal and ran normal? i dont get it
PaTKRider
09-01-2009 06:51 PM
Captain_Sl0w
08-19-2008 07:41 PM
ek20T
12-12-2007 10:31 AM
gotboosthatch
08-07-2007 01:08 PM
Marty
08-19-2005 10:20 AM
