Help me ID this
Old 07-04-2009 | 02:39 AM
Nim's Avatar
Nim
Default Help me ID this
Hi guys, I just picked up a clutch kit for my honda civic and it came with a small tube looking think with a paste in it...
http://img30.imageshack.us/i/04072009085.jpg/
Is this a small packet of grease or something else?
thanks...
Old 07-06-2009 | 06:11 AM
Yes, you put some grease on the splines of the transmission shaft where it goes into the clutch disk. Use only a very small amount because if the grease works its way out onto the friction surfaces, the clutch will not work properly.
Also when installing a clutch set you can save yourself a potential headache by trying the clutch disk onto the transmission shaft before installing it. If it doesn't fit, you have the wrong part for your car. Much better to find that out sooner than later when trying to lift the transmission into place.
stevenc
06-25-2008 09:57 AM
redridinhood
10-09-2006 07:27 PM
superballa22
09-18-2006 05:06 PM
coolguy1234
05-07-2006 08:31 PM
Jas10hon
07-04-2005 10:35 PM
Quick Reply: Help me ID this
