Help identifying air breather parts
Old 07-23-2009 | 12:32 PM
Neon's Avatar
Default Help identifying air breather parts
Hey all, I'm looking to put a stock air box I bought off eBay into my 98 Honda Civic EX. I'm trying to determine what all parts I need. Looking at the diagram from the Honda eStore it shows some parts that are not on the parts list that I'm not sure if I need or what they are.
I was wondering if someone could tell me what parts 29 through 31 are for and what plugs into the 26 clip and what the E-B-1 stands for?
Any help would be appreciated,
Thanks.
Ref. Part Description Part Number Price Req.
1 CLIP, BREATHER TUBE 15772-551-000 **$4.28 **001
2 TUBE B, AIR FLOW 17203-P2J-000 **$11.21 **001
3 COVER, AIR CLEANER 17210-P2J-000 **$13.25 **001
4 RUBBER, AIR CLEAN... 17212-P2J-J00 **$2.97 **003
5 RUBBER, AIR CLEAN... 17212-P2J-J00 **$2.97 **002
6 RUBBER, AIR CLEAN... 17212-P2J-000 **$2.38 **001
7 COLLAR, AIR CLEAN... 17216-PN3-000 **$2.80 **005
8 CLIP, AIR CLEANER 17217-P2J-300 **$1.77 **002
9 ELEMENT, AIR CLEANER 17220-P2N-A01 **$18.01 **001
10 TUBE, AIR FLOW 17228-P2J-000 **$21.63 **001
11 CHAMBER, RESONATOR 17230-P2J-000 **$37.27 **001
12 STAY, RESONATOR 17231-P2E-A00 **$11.48 **001
13 SEAL, RESONATOR R... 17232-P04-G00 **$5.90 **001
14 CASE SET, AIR CLE... 17240-P2N-A00 **$32.71 **001
15 SPRING, AIR FLOW ... 17243-P09-A00 **$2.07 **001
16 TUBE A, AIR IN. 17243-P2J-000 **$25.30 **001
17 RUBBER, IN. SEAL 17244-P2J-000 **$17.20 **001
18 NUT, SQUARE (6MM) 17249-P2J-300 **$9.63 **001
19 MUFFLER SET, AIR ... 17250-P2J-000 **$94.08 **001
20 TUBE, SIDE BRANCH 17281-P2J-000 **$6.96 **001
21 CLAMP, TUBE (D44) 17284-P2J-003 **$9.58 **001
22 CLAMP, AIR FLOW T... 17316-PH3-003 **$5.77 **001
23 SENSOR ASSY., AIR... 37880-P2R-A01 **$23.61 **001
24 LOCK, SCREW 75353-671-000 **$2.38 **001
25 BOLT-WASHER, SPEC... 90029-PHM-000 **$0.35 **005
26 CLIP, HOSE (D13) 91405-PG7-003 **$4.18 **001
27 BOLT-WASHER (5X12) 93404-05012-08 **$0.65 **003
28 BOLT-WASHER (6X16) 93405-06016-08 **$0.61 **003
Old 07-23-2009 | 01:17 PM
jprommel's Avatar
Angry Admin
29 and 31 is the tube that connects from your valve cover to your intake.
http://www.hondaautomotiveparts.com/...BER+%28VTEC%29
these guys i think its 5 6 8 and 10 youre looking for
26 might be the intake(internal?) air temperature sensor. i'm not 100 hundred percent on that one cause i cant really see it that well from the pic
IronBuddha
10-23-2010 08:38 AM
one1rare1boi
07-06-2008 01:07 AM
icecolor
01-24-2008 10:33 PM
jbum
07-10-2007 08:36 AM
Japles
12-18-2006 09:47 PM
