HELP GUYS !!!
HELP GUYS !!!
hey guys =
im new here - my 1st post
need a bit of help with my civic.i drive a 1999 sedan. my AC seems to smell alot and its to much to bare.i just bought this spray. its " Abro Air Clean" for air conditioning systems.
where would be the best place to spray it.they say to spray in the the middle air vents of the car. dont knw wht should i do ?
could u help me out.Thnx u guys !!!
SD -
SD -
RE: HELP GUYS !!!
hey aol ........ do i just push the pipe in and spray in those air vents ????
these are the instructions on the Spray.
directions auto: turn off car engine and use parking brake.shake the can and snake enclosed extension tube all the way into the center register vent.spray the cleaner for ten seconds.remove tube and wait ten minutes until cleaning foam breaks down and drains through the air conditioner system out of the car. (if a black/green residue emerges underneath car, repeat the process until fluid runs clear.) Turn on engine and run the a/c unit on high for a few minutes.
Thats the intructions on the can.should i spray it as they said or should i spray it in where u told me too ????
if i do it ur way - tell me exactly wht i gotta do. keep the ac on ??? blower on ???? or wht ?
Thnx AOL .....thnx alot
SD -
SD -
RE: HELP GUYS !!!
ive never seen the "cleaning foam" type --most of the stuff ive seen is like the air freshener type - i just get a can of lysol & spray in in the outside vent
so i guess you might want to stick to thoes directions on the can ----just make sure your a/c drain hose isnt clogged
RE: HELP GUYS !!!
hey guys !!!!
AOL ..... i did what u told me to do.i sprayed it in the vents of the outside.i kept the AC running..... i seen the ac pipe from the engine giving out alot of water.i dont think the pipe is blocked.if it was then there woudnt be any water draining out right ????
well i put the spray in and i got the scent on the inside of the car.... i kept it running tht way and went for a short drive.on the way back home i swtiched off the AC and kept just the blower on for a min.
i havent checked it today if the AC is ok but i will tomm.
thnx u guys. hope its ok and tht annoying smell has gone.[:@]
will get back to u guys after i check it.
SD -
SD -
blackrocket93
08-05-2005 11:17 PM
