Help D16y8
Old 05-07-2009 | 07:44 PM
chasemclemore's Avatar
Default Help D16y8
Could someone send me a pic of where their throttle stop screw is set at? If at all possible could you set a ruler up against it so I can see how far it goes back... someone adjusted mine and it fell off(before I owned the car, I know better), got a new one but its impossible to set while car is running or even warm... any help would be Greatly Appreciated
Old 05-07-2009 | 07:53 PM
EJ8_Man's Avatar
Are you referring to the throttle cable adjustment screw that attaches to the throttle body? Adjust the cable so that there is no play in the line, but don't make it so tight its opening the throttle. People can send you pics, but you can't really use someone elses setting as yours will be slightly different.
Old 05-07-2009 | 08:02 PM
EJ8_Man's Avatar
This is from the manual
Old 05-07-2009 | 08:14 PM
No not that I know how to adjust that... if you push your throttle like you are accelerating your throttle there is a screw underneath it that has yellow paint on it so it doesnt move...that stops it when you let off the gas it very hard to see on the engine but its there...
Old 05-08-2009 | 06:44 AM
BUMP... PLEASE HELP, it shouldnt take 2 seconds for this pic! OR even just measurements!
Old 05-08-2009 | 09:18 AM
Take the intake off so you can see the throttle plate. Adjust the screw so the throttle plate closes fully, but doesn't slam against the sides of the throttle body.
Old 05-08-2009 | 10:46 AM
I tried that but it made my car idle at 2k when cold and 1500 when hot. and what sucks is the only way to make adjustments is whent the car is cool enough to remove throttle body.
Old 05-08-2009 | 11:10 AM
You've been running without the screw, which may have caused the throttle plate to wear a groove into the throttle body. Check for that and if you have it it's never going to work quite right; best to replace it.
Otherwise if you can get a proper idle by backing off on the screw, do that. If you can't there is an air leak somewhere else. You should be able to stall the engine out by blocking the intake completely. If not it's getting air through a bad gasket or vacuum line.
Old 05-08-2009 | 11:46 AM
Crap I sure hope I dont need another one or this is about to not be my DD for a while... I have blown through a lot of money this month and looks like that is going to run me close to 100 bucks...
Old 12-01-2010 | 09:26 PM
Civic T's Avatar
Is it true that improper throttle cable adjustment will affect auto trans operation?
Quick Reply: Help D16y8
