Help with CEL code
Help with CEL code
I have a 99 Civic LX.. 107k
This morning it threw the CEL. I checked it and this is what is showed.
This reader shows one line at a time here is EXACTLY what was displayed. The car appears to be running just fine but I wanted to get some feedback from the experts here since I'm pretty much a newb when it comes to anything aside from general maintenance.
TIA!
2 CODES
P-1456
P-1456 pd
Mil On
Monitrs
0 inc
7 ready
Misfire
Fuel
Comp
Catlyst
Evap
O2Snsr
O2HTR
TIA!
2 CODES
P-1456
P-1456 pd
Mil On
Monitrs
0 inc
7 ready
Misfire
Fuel
Comp
Catlyst
Evap
O2Snsr
O2HTR
RE: Help with CEL code
Check whether the seal of your gas cap is bad. If so, replace and clear CEL -- remove 7.5A BACKUP fuse from under-hood fuse/relay box for 10 seconds and reinsert. If CEL does not return, then problem is fixed.
By the way, it is also possible that the cap was not screwed down tightly after the last fill up.
Now that I think about it... This is an aftermarket gas cap. My wife drove off with the cap on top of the car after getting gas a couple years back. I wonder if this has anything to do with it. I will look at the cap and see if the seal is screwed up or something. BTW would you happen to know what all the other info in the OBDII reader means...
like:
Misfire
Fuel
Comp
Catlyst
Evap
O2Snsr
O2HTR
like:
Misfire
Fuel
Comp
Catlyst
Evap
O2Snsr
O2HTR
Turbo D
03-05-2007 10:18 AM
b16Ek4
05-25-2005 08:48 AM
