Heater isn't hot, why?
Old 09-03-2009 | 04:45 AM
SupermansDX's Avatar
Default Heater isn't hot, why?
on my 96 civic dx w/o ac i went to turn the heat on this morning and the fan blows but the air doesnt get warm even after driving it around for a while, what am i looking for?
Old 09-03-2009 | 04:48 AM
kanarrjl's Avatar
do you have enough coolant? if yes then it might be a heater core but im not positive
Old 09-03-2009 | 06:22 AM
^ The most common reason for this is not enough coolant. With the engine cold, take off the radiator cap and make sure it is full to the top.
If you have enough coolant, check that the lever on the heater valve on the firewall moves as you turn the dashboard control from cold to hot.
Old 09-03-2009 | 08:07 AM
^ exactly your heat comes from the engines coolant. when the motor is at normal running temp the heater should work if everything else seems to be working
Old 09-03-2009 | 09:23 AM
droopy128's Avatar
Check your heater valve
tgs
03-28-2010 07:12 PM
DeanHensler
01-04-2010 05:07 PM
general23cmp
12-20-2008 10:43 PM
romic00
12-03-2006 08:06 PM
mill$civic
09-22-2006 10:33 PM
Quick Reply: Heater isn't hot, why?
