heater hoses 89 civic help please
I have an 89 civic 1.5L DX hatchback that needs a new radiator. The radiator and upper/lower hoses are all easy to find, but I'm having difficulties finding all the other associated cooling hoses.
I'm looking for all the ones coming off the thermostat, going to the heater core/firewall as well as some of the smaller diameter hose associated with the oil cooler and radiator tank. I'm basically looking to replace all that stuff while I'm in there - and anything else you think I should do while I have the coolant drained!
Any help with sizing or source where I can easily order this stuff, parts numbers? The auto parts store wasn't a lot of help. I should add that I'm not looking for high end performance stuff, just what will work. Thanks!
Chris
Chris
the link that trustdestruction gave you will allow you to purchase virtually any part. Also consider rockauto.com if you want an aftermarket part. the hoses are usually fairly cheap regardless of where you buy them. the radiator on the other hand might vary.
tgs
03-28-2010 08:12 PM
lee norman
05-05-2009 08:03 AM
joelmatt89
02-02-2009 03:04 PM
hatchback virgin
06-11-2008 10:03 AM
