HEADLIGHTS ON PULL ON ENGINE?
Old 02-10-2008 | 12:03 PM
HONDASENCE76's Avatar
Default HEADLIGHTS ON PULL ON ENGINE?
91 CRX DX
TURN ON HEAD LIGHTS WHEN ENGINE RUNNING AND SOUNDS LIKE ENGINE STRAINS FOR A SECOND. LIKE RPMS DROP JUST ALITTLE AND JUST SEEMS LIKE A PULL ON IT.
ALTERNATOR NEW BATTERY USED (TEMP FOR NOW).
Old 02-10-2008 | 08:41 PM
**Alan**'s Avatar
Default RE: HEADLIGHTS ON PULL ON ENGINE?
its called a load all cars do that !
Old 02-11-2008 | 02:05 AM
Never felt this much. just seems mor obvious and this is my 5th honda and 31st car.
Old 02-11-2008 | 05:08 AM
The ECU adjusts the idle speed based on electrical load from a signal sent by the alternator (alternator FR signal). This circuit may be faulty. Alternatively, your new alternator may be faulty.
Old 02-11-2008 | 05:14 AM
well both of my civics do it. if it does it to bad and almost dies than when was the last time you had a tune up? spark plugs might be worn preaty good so when the extra strain is put on the motor it drops out more.
but as long as the engine doesnt die and theirs no whining from the alternator from a bad bearing i wouldnt worry to much.
chmiller25
07-23-2012 11:50 AM
hicksd67
01-25-2012 01:23 PM
Lambo Civic
02-24-2008 03:07 PM
j1nx
47
01-23-2005 11:35 PM
iNTRuDeR
05-15-2004 03:15 AM
Quick Reply: HEADLIGHTS ON PULL ON ENGINE?
