headlights dimming
headlights dimming
it's not really a big deal but it kinda bugs me...
whenever i roll the windows up or down (power windows), the headlights, if they are on, dim a little bit, until i let off the window button. Same thing happens to the A/C, the blower blows less hard while I am holding the window button. Also, the idle changes a little bit while i'm holding the window button.
It happens regardless of which window i am rolling up, and happens if i hold any combination of buttons down at the same time.
Kinda bugs me that it does that, so if it's fixable i'd like to fix it.
Battery is fairly new. Battery wires are clamped on tight. Battery Posts are clean.
Any ideas? I have a multimeter if you suggest any grounds that I should check for continuity.
i checked my grounds to see if they were loose and i couldn't find any loose ones.
i didn't install anything that would relate to this. it's been like it since i bought the car, just never got around to complaining about it
Yeah, I too am thinking that you may have a weak battery or alternator/voltage regulator. Also check the tension of the alternator belt and whether it may be slipping.
This may be a normal situation. The windows use a fair amount of power. At idle, the output from even a good alternator is limited. If you can get 14 volts at the battery at idle with the headlights (but nothing else) on, I'd call the alternator good.
yea i kinda thought it may be normal, because i'm pretty sure it doesn't do it while driving, only at idle, and I know it's a lot harder at idle for the alternator to charge the battery since the crankshaft is turning slower at idle, which could explain the problem.
alright, checked the voltage with the headlights on. i got some fluctuation between 13.97V and 14.30V and then it stopped fluctuating and was a steady 14.28V, sometimes going down to 14.27V, but then back to 14.28V.
