Headlight Delay circuit
I'm looking into making a little circuit that will turn my headlights off shortly after i have turned the ignition off, don't ask why I want to do this, or what is the use.....
Its because I want to.
so far i have found this
R1______________4K7 1/4W Resistor
R2,R3___________1K 1/4W Resistors
C1____________100Î…F 25V Electrolytic Capacitor (See Notes)
D1___________1N4002 100V 1A Diode
Q1____________BC547 45V 100mA NPN Transistor
Q2____________BC327 45V 800mA PNP Transistor
P1_____________SPST Pushbutton
RL1___________Relay with SPDT 10A min. switch
Coil Voltage 12V. Coil resistance 150-600 Ohms
but this will leave the lights on for about 1 minute 30, im looking for around 30 seconds, i know the delay depends on C1 and R1. I am unsure to what values i would need to change these to get a ~30 sec delay.
The other thing i wanted to know would it be possible to just remove the push button, so that the lights would always have the delay every time you turned the ignition off.
RE: Headlight Delay circuit
i would just BUY a control unit
http://cgi.ebay.com/DEI-545T-NITELIT...QQcmdZViewItem
i instaled them on my civic awhile back... they work great! never have to mess with your headlight controls again! hook it up thru your alarm system
it even has a DRIVING light feature BUT of course i cut that wire inside the unit cause those look bad.LOL
yeh i could buy one, but i want to make one, i am just going to take windcalmers advise, and fine tune it.... if anyone else knows what might be a good value, or a calculation i could use to figure it out...
edeffect
06-27-2007 05:39 AM
BrooklynStreetz
20
06-03-2005 09:29 PM
