Ground Wires?
Old 01-01-2008 | 05:11 PM
Stumasters's Avatar
Default RE: Ground Wires?
Personaly, I think it's all in peace of mind. If you replace your grounds, and have some electrical problems years from now, you can most likely rule out ground issues, at least with the battery and engine. I upgraded 2 of mine, to 4 gauge wire and some strong mounting brackets. I don't really remember noticing a single improvement, but at least I know they are strong and new.
Old 01-02-2008 | 08:27 AM
Gene J's Avatar
The ground wire is just one of the wires in your car. Unless you upgrade every single wire you will not notice any difference....and probably not even then. It's just hype to part you from your money.
I have a friend that works at a high-end audio/visual store. He sells lots of $150+ power strips with heavy wires and gold contacts. He neglects to tell the buyersthat they won't see/hear any difference because the wiring inthe walls getting to the extension cord is still the same-old same-old.
clutchjunkie
08-13-2006 08:02 AM
dogma
05-02-2006 01:55 PM
outlaw2049
04-28-2006 10:10 AM
smokingemcee
05-01-2005 01:34 PM
smokingemcee
05-01-2005 02:08 AM
Quick Reply: Ground Wires?
