Ground Wires?
Old 01-01-2008 | 11:45 AM
alecrust's Avatar
Default Ground Wires?
Came across THIS on eBay. Looks interesting.
Can someone explain the logic of how it is supposed to work?
Thanks!
Old 01-01-2008 | 11:58 AM
Default RE: Ground Wires?
it could help alittle BUT thats just because the factory grounds are so small.... cause they where designed to power just the car... so if youve got afew extra electronics... BEST thing to do is upgrade your ground wires....
just look at your factory ground wires.... battery terminal to the passenger inner fender.... WEAK TINY WIRE... maybe 8gauge... and then thiers the wire from the passenger inner fender that goes onto the tranny... SUPRISE old looking has ruffly 2-3inches of bare wire on both ends of the wires LAME... then thiers the front valve cover to front drivers side radiator support with another suprise 2-3inches of bare wire exposed to the elements... and its a tiny wire as well...
upgrade all 3 of those ground wires to at least 4gauge with soldered terminals and heatshrink to seal the ends around terminal and wire and they will do just as good as those ugly @ss ground blocks... with a wannabe mugen sticker on it.LMFAO
Old 01-01-2008 | 12:10 PM
alecrust's Avatar
Thanks! So all it does really is give better grounding when you have lots of electronics. I'll take a look at what I have currently. Thanks!
Old 01-01-2008 | 01:04 PM
riceburner700's Avatar
i ran one of those on my civic back in the day, it smoothed out the idle a little bit. it just grounds better. it looks all bulky sitting on your battery. i jsut ended up selloing the wires to my friends
Old 01-01-2008 | 01:08 PM
alecrust's Avatar
So why did you sell it if it smoothed your idle?
Old 01-01-2008 | 01:12 PM
because im putting a different motor in the car im gonna make my own tucked custom ground wires
Old 01-01-2008 | 01:18 PM
alecrust's Avatar
Fair enough. So you would suggest getting them? How do you mean it smoothed your idle? In what way?
Old 01-01-2008 | 01:28 PM
Civic Si 00's Avatar
ORIGINAL: riceburner700
What if I make my own ground wiring. I know that Scosche is pretty good. Oh I was to lazy to start another thread about the same Subject.
Will this wires be good for grounding
Old 01-01-2008 | 01:39 PM
alecrust's Avatar
And what is the benefit of making your own?
All these questions!
Old 01-01-2008 | 01:42 PM
1st you know what quality you are using
2nd Sometimes it'scheaper to make your own + I enjoy do to most of the stuff on my own.
Quick Reply: Ground Wires?
