Grinding gears
Old 01-05-2008 | 08:51 PM
Default RE: Grinding gears
In addition to checking the fluid level in the clutch master cylinder, you might do the same for the transmission. In fact, based on your shifting problems, you might want to drain the old transmission fluid and replace it with new.
Old 01-05-2008 | 09:04 PM
MasterJT's Avatar
Does that cost alot of money? I dont have alot of money right now.
Old 01-05-2008 | 09:08 PM
ORIGINAL: MasterJT
Replacing the transmission fluid with the recommended Honda product might be pricey; however, it's free just to check whether the transmission fluid level is low.
Old 01-06-2008 | 04:48 AM
my94civic's Avatar
I had problems with grinding when i shifted above 3k from 2nd to 3rd, apparently this is a common problem. Though all i needed to do was drain transmission oil, and fill it back up again, i think it was about 4 litres of oil, so thats how much it should cost you, the price of the oil
Old 01-06-2008 | 02:23 PM
mill$civic's Avatar
I had the same problem from 1st to 2end, it was really really bad in the winter as the fluid with be really cold. What I did was buy a transmission fluid called GM synchromesh from the GMC dealership. I put it in over 2 years ago, and let me tell you, since then, not one grind, it makes a world of a difference, this stuff took care of my grinding problem 100% and I'll alwaysuse it for now on. If you search Google for "GM synchromesh" you will find pages and pages of threads on this stuff being used in every type of car...and its funny, when I went to get this stuff from GM, he actually guessed that I was using it in a Honda (I wasn't driving my car ether).
Old 01-06-2008 | 05:29 PM
MasterJT's Avatar
Alright thanks for the info. Im more worried about the engine now. Evertime I start it up after it sits for the night it turns on then turns off. Then I turn it on again and its fine. I hope nothings wrong with it. It doesnt do it if Im driving places and have to turn it on again. Only after it been sitting atleast a night.
Old 01-06-2008 | 05:43 PM
ugh3012's Avatar
If it has been sitting in the yard for two years then all fluids should be change.
D17Punk
11-09-2007 11:06 AM
SI_smiley07
08-10-2007 02:39 PM
ksull
07-15-2007 08:52 AM
hondabboy
03-14-2005 05:40 PM
niteryder
01-08-2005 08:49 PM
Quick Reply: Grinding gears
