greasy oily substance in intake pipe?
So i was removing my intake filter to see what size it is because im getting an AEM filter. I went to whip the inside of the pipe to see if there was any dust on it, and there's some kind of greasy stuff on the bottom of the pipe. What could this be?
That is the reason for all the junk in the intake pipe then. Cheap filters don't filter much. Good thing your getting an AEM filter. It will make you and your car happier. While your there it's prolly a good idea to clean out the intake pipe and your throttle body. With all the excess dirt that is in there it's best to clean it out now.
Its only in the pipe, more towards the filter end. its dry around the entrance on the throttle body.
well you can easily get some oil in the intake.... remember you have a valve cover hose that goes into your intake which means fumes from the oil and such geting sucked all around there and after so much oil film in the intake, then you cut the motor off which isnt sucking it thru burning it anymore, so it simply follows gravity and slowly oozes down the intake and around your filter. if you think the filter opening is bad you should pull the intake off and feel inside the throttle body..... it will be black from the oil!!!!!!!
nothing to worry about.
WTF i just got my new filter. it said 3.50'' so i thought that was the size of the rubber piece that gos on the intake. It to big, its like 4'' and my intake pipe is 3''.. So i guess ill have to buy another one if the eBay seller dos int what to exchange for a 2.75''. $50
enigma34
06-17-2008 09:29 PM
84runner
09-24-2006 07:55 PM
