got no interior lighting
ok so I installed a tach in my car and then it all started I connected the wire to dim the light on it to my dimmer and now for some unknow reason wene I turn my lights on at night of my panel lighting goes out
dito... i wouldnt hook up the tachs light to the dimmer switch. either wire it to the parking light wire on the switch itself or do some soldering and wire it to a dash light bulb, easiest to wire it off the back of the gauge cluster.. pull the cluster and you can see 2 black wires running from one bulb to the top small bulbs. simply tie into that wire for the tachs backlighting.
i dont remember which wire position is which so just test it with a light tester with the parking lights on.
The dimmer works by controlling the ground wire from the dash lights, not the power wire. The light on an aftermarket tach can't be wired into the circuit unless it has two wires giving dedicated access to both leads of the bulb.
