gears grind
RE: gears grind
ORIGINAL: **Alan**
your syncros (if thats how spell it) are probly wearing out... do you have a short shifter? if so it might not be on tight and dosnt let the gear fall in properly
RE: gears grind
really? mine moves a little bit but thats it. my car would grind 2nd real bad so i checked it out . i grabbed the shifer and moved it from left to right and i could feel that it wasnt tight so i tighted em up and no more grind . so i would check that out first and go on from there.
RE: gears grind
just right under.. in the middle the exhaust runs by there so make sure its been off for a while and take a flash light of some sort lol its only one bolt i forgot wut size it was ... im guessing 16mm maybe lol
RE: gears grind
if i remember correctly its a 12 and hopefully its the right short shifter. if its not for your car the ball may be a little big not allowing to fully engage in the gear. also check ur bushings those are right there.
RE: gears grind
ORIGINAL: civicraider
