fuel pressure gauge
I think your talking about "FUEL PRESSURE GAUGE BANJO FITTING "
scroll down and read this i think this is what your talking about not 100% sure but here this link FUEL PRESSURE GAUGE BANJO FITTING 12MM BOLT KIT 1/8 NPT | eBay
That ebay part would work. It replaces the fitting at the outlet of the fuel filter. I would suggest using it for temporary tests only; it appears to be made of brass and might break if properly tightened like the steel bolt should be. If you want a permanent hook-up on your car you could remove the fuel rail and drill and tap it with a test port.
chuzie
05-26-2012 05:01 PM
addiction2bass
10-09-2009 03:25 PM
siwel177
12
07-17-2009 06:47 AM
phan10m
07-07-2007 04:27 PM
TheBlackCivic
07-16-2006 11:45 AM
