fuel gauge
When that happens, how many gallons does it take to refill the tank? If you need 11 or more gallons, the car is actually empty but the gauge shows wrong. If you only need 7 or 8 gallons it's really 1/4 full, but the pump is sucking air because like 94 said some of the fittings on the bottom of the pump are bad.
well if you dont wanna mess with it then just leave it and dont go below 1/4 tank, you should be fine
edit: you can pul it and inspect it , i dont think its the fuel pump, its the screen or it wasnt put in correctly
