found alternator wire melting?
Old 08-03-2008 | 09:50 AM
If it melted right at the alternator and not along its entire length, it could be the nut was not tight, the terminal was bad or there is a defect it the alternator causing overheating.
As stock configuration, the alternator wire goes to the underhood fuse box, not directly to the battery. Another white wire goes from the battery to the other big terminal in the fuse box. It is important to have the proper wire on the proper terminal.
Old 08-03-2008 | 11:37 AM
o i couldnt remember where that stock white went. i left mine hooked up but i do have my new wire fused on my main audio fuse block i have under the hood.
i choped my factory battery terminals off shortly after i bought the car over a year ago.LOL
Old 08-03-2008 | 06:07 PM
asianboy's Avatar
Originally Posted by RonJ
By the way, a bad alternator/WHT wire could cause an engine idle/running problem.
yay!!
this is what i was hoping someone could verify. i have been having this idle issue for a while now and i could not figure it out. i did all the necessary fixes to find it and to no conclusion. i hope this will finally close the chaper of my mysterious idle problem so i can move on and do some other mods to the car. i have not been able to drive this thing for almost a half year now. so many little issues keep comming up.
Old 08-04-2008 | 08:49 PM
asianboy's Avatar
ok i just looked at it today.
it looks like the nut holding the white wire is almost off. i tightened it and drove it around before i decide to do anything else. the electrical is back to normal. i dont think the wire is totalled yet.
as for my idle issues. it still continues. this time it just drops and stalls or it may drop and stall after a couple of rpm bouncing..
i am now wondering if its a bad distirbutor?
anyone know how i can test a distirbutor?
unless this is a different problem.
enigma34
05-21-2008 02:19 PM
fdiddy
03-10-2008 06:55 PM
xsdudztx
08-14-2007 05:45 PM
matthewc
07-02-2007 07:14 PM
SPLAT
12-11-2006 06:06 AM
Quick Reply: found alternator wire melting?
