fix to interior squeaks/creaks
Old 03-15-2007 | 12:29 AM
98civex's Avatar
Default fix to interior squeaks/creaks
is there a solution? sometimes it drives me nuts hearing my door panel and other interior panels scream out tiny squeaks ha. anyone else share my pain?
Old 03-15-2007 | 02:38 PM
Live_4it's Avatar
Default RE: fix to interior squeaks/creaks
yeah, I got a few. I think my exhaust has helped jarred a few things loose. You could just try to find where the noise is coming from, and tighten any screws or replace something.
Old 03-15-2007 | 03:31 PM
My04Civic's Avatar
Administrator
i dont share your pain bro, yeah, just fix the squeaks, or wear ear muffs
Old 03-15-2007 | 03:53 PM
gin0o0o's Avatar
haha i hear yah. i had this stupid hood squeak that sounded like hell! when the car turned or idled low and esp when the subs were hitting. (you could hear the rattling outside). but i fixed that with some electrical tape =).
Old 03-15-2007 | 04:21 PM
Street Sniper's Avatar
Chassis stiffening will help that... or just turn your stereo up.
Old 03-15-2007 | 04:32 PM
Remmy's Avatar
Have you replaced your 6x9's in the back? If so, doulbe check that back deck panel. Its a son of a bitch to get back on the right way.
Old 03-15-2007 | 04:33 PM
drbyers's Avatar
cars are just prone to squeaks as the years go by.
Old 03-15-2007 | 07:15 PM
98civex's Avatar
My main annoyance is my drivers side panel. I had to remove it twice and now it doesn't sit as tight as it did. Nothing broke, anyway to make it 100% solid? Right now its like 95% if I had to use percentage ha
Old 03-16-2007 | 06:15 AM
loFreqncy's Avatar
I would try some spray silcone on squeaks you can't exactly reach. I have an annoying one up under the dash somewhere(sounds like the center), that I hope to get one day soon.
Finally got my passenger kick panel back in the right way, but the damn plastic screw thing is useless.
Old 03-16-2007 | 02:45 PM
POLYTHING's Avatar
ORIGINAL: loFreqncy
not silcone
use this instead (Honda White Lithium Grease)
4 bucks at the stealership or you can get the aftermarket one in AUTOZONE, around 3-4 bucks
spray them in door jams, trunk laches, hood,
good luck
Quick Reply: fix to interior squeaks/creaks
