Mechanical Problems & Technical ChatIf you've got a problem you just can't figure out, a noise you can't diagnose, or a check engine light that won't go away, ask about it here!
need help, the relay seems to be fine, so does the pump, it did fire once then stopped again, tried hooking up a voltmeter to the plug and showed no power going to it... could it be not grounded out???
