Fan doesn't blow.
Fan doesn't blow.
Hi guys,
I have an 01 civic and the fan doesn't blow. It won't blow cool, hot, or AC. I believe the AC still works because when I turn it on the vents feel colder.
I checked the fuses and none are blown, I'm guessing the fan motor is probably shot. Anyone know where the fan motor is? Any other advice on how to fix it?
Thanks
Thanks
RE: Fan doesn't blow.
I'm guessing, though I could be completely wrong, it's where it always was in the older models. Under the dash, on the bottom, on the extreme right end. Basically just above the passenger's right foot. You may have to remove a trim panel first to see it.
It can be a bear to remove so test it first. When you find the motor, turn on the fan and see if voltage is reaching it. Or unplug it and connect a car battery to the motor with two wires and see if it runs. If the motor seems OK, the switch in the dashboard is usually the problem.
Steve925
06-27-2010 03:21 PM
zeal
12
06-18-2006 11:09 AM
