exuast leak
get the car up on jackstands fully examine the exhaust piping for holes and **** if you dont see any fire up the car, and run your hands along the pipe feeling for the escaping gas, have someone rev to get the air moving faster if u want. try that...
What makes you believe that you have an exhaust leak? As Josh says, check for obvious holes or cracks throughout the entire exhaust system including the exhaust manifold and catalytic converter.
well i replaced the cat abbout 3 monhts ago im thinking it might be comming from there and i think i have one because i can here a kinda ticking sound its not to bad tho i think its just a slight leak
With the engine idling, hold a rag in your hand and use it to cover the tail pipe to build up some pressure. You will hear the gas hissing out where there is a leak. Having an assistant to block the pipe helps as you can listen more closely to localize the leak.
Safety tip: Don't do this test in a closed structure or garage lacking proper ventilation.
Dwack1992
04-08-2013 04:05 PM
theRDRman
11-28-2011 04:18 PM
cool chris
04-21-2005 09:33 PM
