Engine surges
Old 08-11-2004, 03:14 PM
Default RE: Engine surges
well, i paid $87.00 for the diagnosis and replacement of the ground strap so, depending on the Dealer since they are all independently owned, it will probably be somewhere around there. The thing is, by father took the car in and it was fine so they couldnt find anything wrong, then as he was driving away it started acting up, so he took it back and since they saw the problem in action, they were able to fix it.
I work for VW headquarters and I notice east coast Dealerships seem to average $80 or so for a diag and west coast are like $90-100, and I think Honda's labor rates are much less. At least clean all your grounds really well and see if that fixes it for ya. If not, get it to act up at the Dealership and you are golden.
Hope this helps others out. If you have this problem, try all the ground cables first if the maintenance is up to date. Seems like a pretty solid solution to this concern.
  #22
Old 08-11-2004, 07:11 PM
ohbiskits's Avatar
alright thanks man...
  #23
Old 08-12-2004, 08:37 AM
no problem man.
(I had them show me the ground cable for kicks, exactly where it is at, it goes from the main wiring harness near the battery and bolts to the thermostat housing under the intake in the rear of the engine. What a STUPID idea, at least most of the other grounds are right in front and you can obviously see if they are jacked up.)
  #24
Old 08-12-2004, 03:02 PM
ohbiskits's Avatar
me and my dad are gunna look tonight...was the ground just loose..? was the wire bad..whats the deal...how did they fix it?
  #25
Old 08-12-2004, 04:39 PM
It was corroded so much it was not making a metal on metal contact. When I got home I made sure EVERY ground I could find was nice and clean and the contacts were good.
Car runs like a beast now! [8D]
  #26
Old 08-12-2004, 08:32 PM
ohbiskits's Avatar
alright thanks man...i took a little wd 40 and a wire brush to it and hopefuly im through now...it didnt do it at all tonight so maybe thats it...thanks again bro
  #27
Old 08-16-2004, 11:06 AM
no problem man, just make sure every single ground it clean, there are some hidden ones like the one i had the problem with. Hopefully it takes care of your problem as well.
PRamon
01-12-2010 09:22 AM
point78
08-22-2006 05:40 AM
TravisR
04-18-2006 09:58 PM
redcivic96
11-12-2004 05:10 PM
importmech
10-14-2004 09:25 PM
Quick Reply: Engine surges
