engine revs up and down
Old 03-19-2007 | 11:47 PM
93delsol's Avatar
Default RE: engine revs up and down
how did you close off the iacv,
  #22
Old 03-20-2007 | 08:08 AM
ORIGINAL: C1V1C_C0UPE
It sounds like it could be the fast idle thermo valve. Take off the pipe that runs from the throttle housing to the air cleaner, you should see 2 holes just before the butterfly, cover up the bottom hole with your finger and see what happens if idle settles down then you need to take off the FITV and clean it (its located at the bottom of the throttle housing).
I dont believe the d-series has an FITV does it?
  #23
Old 03-21-2007 | 06:01 PM
C1V1C_C0UPE's Avatar
I have a D15B7engine in my coupe and the FITV was the cause of my rough idle. The IACV should be the top hole so if you cover that one up the car should almost if not die and rev to about 400 rpm.
rcgtsport
08-29-2012 06:43 PM
harleycivic410
07-28-2012 06:02 PM
k.houle
08-02-2010 12:19 PM
Platti J
02-06-2009 03:16 PM
MichiganRice22
05-20-2005 09:34 AM
Quick Reply: engine revs up and down
