Engine No-start after replacement.
Old 04-30-2007 | 08:06 PM
BIMMERGUY's Avatar
Default RE: Engine No-start after replacement.
Any suggestions?
Old 04-30-2007 | 08:36 PM
hatch46580's Avatar
did you use your old dizzy??? if you used one from a diffrent motor use your old on.the new one might have a bad pick up or a bad coil in side it. Also did you check that little ground i told you about that attaches to the thermostat housing, if your not sure were this is follow the lower radiator house to the back of the head, there should be a little cluster of ground together with a little ring terminal, and a little 10 mm bolts holds it to the houseing.
Old 05-01-2007 | 07:49 AM
BIMMERGUY's Avatar
No I used all the orig accessories, and wire harness. The only thing swapped was the "core engine" including cylinder head. I'll double check this ground point. Do you think thiswould cause the car not to run? I have no fuel pressure, as the pump will not go through its startup test. and I have no spark.
Old 05-01-2007 | 08:14 AM
BIMMERGUY's Avatar
I just spoke with my uncle who is a Service manager at a lexus dealer. He told me to check the Crank sensor, Because it sends the signal from the #1 cylinder at TDC to energize the computer. Also, He told me to check the Oil pressure sender. But I think my fuel system would still at least power up.
Old 05-01-2007 | 11:22 AM
hatch46580's Avatar
if that little ground isnt hooked up the car will not sart. there a few grounds put all together. im not sure what the 3 or5 grounds go to because the in the harness, but i spent 2 days before trying to figure out why my swap didnt start. so now thats the first thing i check..
Its not a body ground, there grounds for like dizzys and stuff like that.
let me know if that works because it cant be to many more things, im getting stummped...lol
Old 05-01-2007 | 07:37 PM
BIMMERGUY's Avatar
Excellent. I will look at it first thing next week when I return home...... I'll post with the findings!
Thanks for all the help!
By the way, Is there a main relay on this car? I was unable to find one. Or a fuse for the computer?
Old 05-01-2007 | 09:09 PM
hatch46580's Avatar
your main relay is above your hood release a black box with a metal strap to hold it on
Old 05-19-2007 | 06:13 AM
BIMMERGUY's Avatar
Well, I double checked, And The ground on the thermostat housing was hooked up, But it was very loose. I cleaned up the connections and gave it a try. The first thing I noticed when I turned the key was the fuel pump kicking on, then I cranked if for about 2 minutes (with small breaks for the starter) and it fired right up.
Now my only problem in the idle. It runs well, but when i come to a stop the idle surges. then it levels off..... May be a vaccum leak....?
Old 05-19-2007 | 06:44 AM
hatch46580's Avatar
ya sounds like a hose left off or a damged hose, or did you bleed your coolent.
I knew it was those damn grounds...LOL
Old 05-24-2007 | 04:23 PM
BIMMERGUY's Avatar
It is all set.... The car worked it self out...... Runs like a top.
Thanks.
edubs
04-29-2012 08:39 AM
MasterJT
05-15-2010 05:45 PM
Davidov
06-14-2007 10:28 AM
muke420
05-03-2007 05:07 PM
lvo civic
03-16-2006 12:43 AM
Quick Reply: Engine No-start after replacement.
