engine light when boosting
#22
RE: engine light when boosting
i just fitted the missing link part but i dont think i put it on correctly this is what i got with no instructions.
the missing link
one O ring
2 longer bolts
a piece of foam?
and some washers
there are 3 holes in the link one on the top( large hole with a ring around it)
one on the bottom (very small)
and a small one on the side?
i had no idea so i guessed i put the foam in the large hole, put the o ring in the groove around the large hole, then put the map sensor on the top and attached it to the original mounting place using the larger bolts.
the car does not error but also does not run properly
any ideas did i do it right.
the missing link
one O ring
2 longer bolts
a piece of foam?
and some washers
#23
ORIGINAL: extreme
tell me exactly which management for my car and i will look into buying one.
ORIGINAL: Forty04
ecu chipped w/ crome and a tune will definitely help. YOu can't just toss bigger parts at the fuel system and expect it to magically create good AFR's
#24
i scrapped the missing link what a pile of poop i used some of those one way valve thingys that go from the inlet manifold to the brake master cyclinder thing i got them free from scrappy much cheaper
#25
ORIGINAL: Forty04
ORIGINAL: extreme
ORIGINAL: Forty04
#26
Seriously, it appears to me like you have no idea what the hell you are talking about. First and foremost, you came here to ask questions and dont listen to a damn thing anyone says? Have a little more respect in yourself and more importantly everyone on this forum. They try to help and you blow them off. Remmy, Mossy, and Forty all know their stuff and you ignore them. Also, why the hell would you add something like a turbo without doing research? It seems to me like you slapped the basics on and forgot the important stuff like the ecu and a tune.
