engine light when boosting
Old 11-17-2007, 04:58 AM
extreme's Avatar
Default engine light when boosting
my engine light comes on when boosting then the car doesnt idle properly up and down between 1 -1.5k any ideas guys. i have not changed anything on the car apart from adding the turbo kit.
Old 11-17-2007, 05:03 AM
Default RE: engine light when boosting
Are you able to retrieve a check engine light code?
Old 11-17-2007, 05:07 AM
extreme's Avatar
if you tel me how i will check
Old 11-17-2007, 05:10 AM
What year and model/engine type Civic do you have?
Old 11-17-2007, 05:13 AM
extreme's Avatar
its a 94 civic sedan 1.6 sohc vtec D16z6 i belive
Old 11-17-2007, 05:20 AM
The procedure is described in the picture. If you succeed in retrieving a code(s), then you can post it in this thread to receive more feedback.
[IMG]local://upfiles/25538/403F1C6A425F4E019B7DC79190CEBC80.jpg[/IMG]
Old 11-17-2007, 05:29 AM
extreme's Avatar
ok i will check but when i turn the car off will the ecu keep the fault code beacause when i turn it back on the l;ight goes off untill i hit boost again
Old 11-17-2007, 05:34 AM
If you have a code stored in the car's computer, turning the car off should not clear the code. Codes are cleared if you disconnect the battery or remove the 7.5 A BackUp fuse in the under-hood fuse/relay box.
Old 11-17-2007, 05:38 AM
extreme's Avatar
just been looking on ebay and found a OBX MAP SENSOR CHECK VALVE LINK shound one of these be fitted or car i run with out because this could be my solution.
Old 11-17-2007, 06:35 AM
Fiirkan's Avatar
did you get a tune? engine control management? anything that is REQUIRED for boosting?
Quick Reply: engine light when boosting
