Engine Failure
Engine Failure
I have a 01 Honda Civic sedan, the engine has 135k miles and had absolutely no problems, you could barely hear the engine running except for the cold air intake sucking in air. I had my oil changed at Jiffy Lube (I know now that was a big mistake, so that will be the first and last time I let someone else change my oil) and after 120 kiles the engine began knocking, power was lossed and the engine stopped. My own diagnostic was that the oil had leaked out over the 120 miles which cause the engine to seize and throw a rod. Jiffy Lube says they are not liable because of engine failure. The drain plug was half way out and oil was sprayed all over the undercarriage. A local mechanic said the same thing, and that it was obviously thier fault. Now my question is how likely is it for an engine to just fail with no prior mechanical issues?
RE: Engine Failure
They are liable because they didn't put the drain plug in properly. You could do that to a brand new car and it will die in 120 miles or however far it goes before all the oil leaks out.
Though the amount they owe you is not a new engine, but a used one in equal condition to what yours was before they messed it up.
RE: Engine Failure
Ask the manager of Stiffy lube where he went to school, if he says The university ofMcDonalds thats why they are not responsable. Other then that talk to the corporate end of Stiffy lube. The last 2 motors i replaced at my shop the oil change places that blew them up at least paid for 75% of the job to replace the motor with a compairable junk yard engine.
Good luck !!!
Good luck !!!
RE: Engine Failure
You should have made the habit if someone else does your oil, ALWAYS check to make sure the plug is in there tight. When I bought my Civic new in 1999, it had about 2000 miles on it and I took it in to Jiffy Lube, and they said everything is good to go. I look it the plug and it wasn't even there, and somehow ALL the oil they just put in leaked out everywhere. If I had drove away, they would have been paying for a new car since they would have ****ed up my new car with not even 5000 on the odometer.
acertaindrug
02-14-2011 10:58 PM
