engine does not crank ....?
Old 06-16-2010 | 11:57 AM
wicked696's Avatar
Question engine does not crank ....?
i just put new cv axels on my 97 honda and tha F**** thing doesnt even crank?? i cant seem to diagnose the problem any1 on here have an idea ?
Old 06-16-2010 | 12:03 PM
First forget that you put new axles on, that should not have anything to do with it. Go through the standard diagnosis of a car that won't crank.
Do you hear any noise from the starter at all? Do other electrical things in the car still work? Do the headlights and/or dome light stay on when you try to start, or not? If it's manual, you could try to roll-start it.
Old 06-16-2010 | 12:11 PM
wicked696's Avatar
the starter seems to be making no noise when i try to start it , um.. the lights inside of the car all work ,dome light, head lights,etc. .ill defiantly try to roll start it..
Old 06-16-2010 | 12:17 PM
Some possibilities to consider:
-Low battery charge
-Bad safety starter switch at top of clutch pedal or the rubber stopper has fallen out or broken
-Bad starter
-Did you happen to disconnect the transmission ground wire when you replaced the axles?
Old 06-23-2010 | 09:24 PM
wicked696's Avatar
Thumbs up
thanks ron j for your help man,
zerojett
10-18-2011 03:01 PM
crx1984
04-16-2007 07:46 AM
snosurfa7
07-11-2006 01:19 PM
Quick Reply: engine does not crank ....?
