engine bogs and almost dies when ac is on..
i tried to bump the idle but it didnt help much,,,,,used the haynes manual procedure. whats going on here and what can i do?
the ac compressor is only a couple years old,,,
thanks guys
thanks guys
I assume that the A/C otherwise works and it gets good and cool inside the car. Check that the condenser fan comes on whenever the compressor is engaged. If the fan doesn't work, the system will overpressure and put a heavy load on the engine. It will also start cycling on and off and of course it won't cool very much at all.
The IACV needs to be able to give the engine extra air to keep the speed up under the normal load of the A/C. Clean the valve and also the passages in the throttle body where it attaches.
The motors do go bad. First check is to spin it by hand with the key off, if it won't turn freely it's definitely bad. The relays are mounted near the condenser and the left headlight. Check that power is reaching the motor with the A/C on. It's also possible to lose the condenser ground, that ground wire only affects the condenser fan.
This is all about the condenser fan on the left (driver's) side of the car. Note that the radiator fan need not necessarily come on when the A/C is on. Unlike many cars, it's separate from the condenser and only comes on in response to engine temperature.
drewrussell2011
05-17-2014 07:57 PM
TxFireman1972
22
09-21-2010 04:48 AM
