eng revs when brake applied
2003 civic lx automatic....as I pulled up to a stoplight and applied the brakes, the eng kept revving higher the harder i pressed the brake. and the brake pedal went to the floor?!?!?!?I already checked to make sure the floor mat wasn't hung up on the gas pedal.any ideas??
problem solved......decided to hose the throttle body down just to make sure nothing was sticking...found that a mouse or rat had come through the air intake chewed through the air filter and had proceeded to build a nest in the throttle body throat.cleaned it all out and replaced the master cylinder.all good now.
thanks to all for the suggestions
Miken70
10-25-2012 04:33 PM
tim.ocallag
12
08-05-2011 07:16 PM
djcompton
05-06-2009 09:07 AM
lowranchero
24
02-18-2008 03:56 PM
zhmendak
04-22-2007 12:51 PM
